Easy Way to Re-Organize Saved Lists
Carl Reid shared this idea 9 years ago
Planned
Right now whenever you save a new chart/metric set that chart/metric set goes to the bottom of the Saved list. This becomes a headache if you have a good number number of Saved charts/metric sets, as you have to scroll down the page to open it.
Maybe insert a search function after clicking "Open" in Charts/Tables, or a file system similar to the file system on a computer...where a user could hypothetically place a new chart in an "econ" folder.
Just need to solve the issue that is making Saved items easier to get to when a user has a large number of them.
Replies (5)
This is largely addressed in the new design which does a popup, alphabetically organized, with multiple sorting options + search
Additional comment from Rushi:
As our clients build more and more with YCharts, it just having a "dropdown" when trying to open a chart is becoming difficult because they have to look through many charts or screens to find the one they are looking for. Perhaps, similar to the dashboard tabs, we can make "folders" within the open tab to make it easier for users to organize their saved items.
Thank you Ara!
Ara, are we do not have plans for searching as far as I know. Should we add that to the new design?
I think we might have had it at some point and took it out for simplicities sake, we can certainly add back...
