Customizable Axis (including forcing items on same scale or vice versa)
Under Consideration
Clients often run into problems with the pre-set axis
requested by bill newell (pro client) on 3/29/16 again
here's a good example of why this is important. visually on the chart it would appear the the S&P's P/B is lower, however, if you take a glance at the y axis' that is not the case (S&P P/B is actually higher)
