Add Baseline to Chakin Money Flow Indicator on Technical Charts
Under Consideration
I wanted to make a suggestion to make your technical charts easier to read. The primary thing I wanted to point out is how much easier the CMF indicator is to read and interpret on the stockcharts.com version. Since they have a line at zero I can easily tell with a glance if the CMF is positive or negative which makes the chart much more useful and user friendly. Can Ycharts add a similar baseline to your CMF charts so make them easier to use? The red or green fill is a nice bonus but adding the baseline will make a huge difference in readability.
http://stockcharts.com/h-sc/ui?s=MSFT&p=D&b=5&g=0&id=p18484987333
Thanks, Chris
Christopher D. Nei
Portfolio Manager
I like this idea
Would be part of a larger charting software update
